This is a long shot...but if you can separate out the plastic slider you might be able to get it "plastic welded".
Alternatively there are some businesses which do rapid prototyping and have 3D printers. They should be able to replicate the part fairly easily...
as for the metal lug... perhaps you can get a small "blob" of weld laid on the part then shape it with a Dremel...
