G'day Xul,
Welcome to the forum,
You will need a bit of luck finding a 90 of that era. They were not sold in Aus until 2003 to 2005. They didn't sell a lot of them then because of the limited size - and probably because the Jeep Wrangler was 10 grand cheaper.
I have a 2005 90 and wouldn't sell it for that money - yet.Most advertise in the low 30 grand and you could probably find one with higher kms for high 20's. It would have to be damaged or clapped out to get one cheaper.
Perhaps with the new PUMA 90s reappearing this year the second hand market will drop a bit. (For your sake - not mine)
Occasionally earlier 90's pop up on the second hand market that were personal imports. Although I have only seen a few in the last couple of years.
A 110 is probably a more realistic proposition for you and you will find plenty in that price range and era. Either an early td5 or a late 300tdi.
I quite like the 2 door hardtop, tdi's from the mid 1990's. But there are plenty of 110 Wagons to choose from. If you are not familiar with them it would be worthwhile paying for an inspection by an expert.
Don't let anyone tell you - "They are made of aluminium - They don't rust". It is a con. Whilst most of the panels are AL, they have steel firewall and chassis which will rust almost as quick as a toyota.
Good Luck with your search
