Results 1 to 2 of 2
Thread: I want your help !!
    Blue eagle TD5 Guest
    I want your help !!
    Hi for all, (engine td5)
    Is it possible to put an oil cooler outside of the engine with oil filter
    Note that the engine oil had merged with the cooling water
    Please advise
    to really no.
    although the internal leaky bit of the cooler can be replaced with a bit of pipe with the same fittings on it as original bit. Consult your local hydraulics specialist.
