Page 30 of 41 FirstFirst ... 20282930313240 ... LastLast
Results 291 to 300 of 408
Thread: The ultimate solution to Td5 vibration / knocking
  1. #291
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by Fluids View Post
    Mine will upshift to 4th at around 52-54km/hr on light throttle .... medium to aggressive throttle is around 65.
    A "tighter" TC with less slip would be a nice thing
    My shift points all seem to be OK, maybe 2nd to 3rd could be at 5km/hr lower (around 37-38km/hr) but I'd prefer to have the TC lockup around 6-8km/hr lower than it does now.
    Checked my upshift to 4th while I was out this morning. With a medium throttle on a slightly undulating road the auto was upshifting to 4th at around 60km/h with a stock TC.
    If you have a nanocom or other diagnostic tool that can give live readings of the Auto ECU solenoid valve 1 and 2 indicate the current gear the ECU has selected. Solenoid valve 1 status changes from ON to OFF when the transmission shifts to 4th, so it's fairly easy to monitor on a Nanocom One. Solenoid Valve 3 indicates the status of the TC lock-up clutch - On is engaged.
    Paul
  2. #292
    Sep 2011
    France
    Quote Originally Posted by Oggie View Post
    Don't want to hijack this thread will start a new one I need to investigate this upshift/km a bit more
    Good thinking mate. Once you start a new thread on shift points, post the link here. I will video my tach/speedo as I go up thru the gears so we can compare how our Discos shift.
  3. #293
    Nov 2011
    Wales
    Vibration Problem Solved
    I had the same problem with my 2003 Dicso2 TD5 Auto Facelift, vibration & resonance at about 2000 rpm including when parked.
    It drove me absolutley mad & I spent hours searching various LR forums. I got all sorts of suggestions including Propshaft, Engine Mounts, Crankshaft Pulley, Torque Converter, Flywheel etc etc.
    I had virtually become resigned to putting up with it when I stumbled across the cause, more or less by accident.
    Turned out to be the Plastic Covers over the sills which I refitted and, hey presto, the resonance has gone.
    Hard to believe that something so loud & annoying could be caused by something so simple & easy to fix
  4. #294
    Sep 2011
    France
    Quote Originally Posted by grendawkin View Post
    ...Turned out to be the Plastic Covers over the sills ...
    Could that part also be described as the door threshold covers? I'm not sure which part you're describing. How about a picture for us?
  5. #295
    Nov 2011
    Wales
    Quote Originally Posted by RenoHuskerDu View Post
    This is the Plastic Trim which covers the sills along the length of the car, externally front to back. Sorry, no pics.
  6. #296
    Mar 2010
    Patagonia
    Jun 2007
    Less throttle input is required to pull along and the transmission upshifts ever slightly earlier...
    Torque Converter lock-up WILL remain unchanged though - it is hard coded in the TCU
    yep, I would agree with this, this is inline with the usual feedback we get, shift points may be very slightly earlier, lock up speed will be unchanged, the converter cannot alter this, it locks when the ecu tells it to.
    the big difference is the lower stall speed, ie less 'slipping', meaning it feels less 'revvy' when accelerating,
    Dave Ashcroft
  8. #298
    harvey130 Guest
    Mine fixed
    Hi all
  9. #299
    harvey130 Guest
    Hi all, I have read in this posting about the handbrake been the problem.......... wow wow wow wow------ Handbrake, Handbrake, Handbrake, Handbrake ABSOLUTELY, ABSOLUTELY, ABSOLUTELY, ABSOLUTELY. Had to fill with diesel so just put the handbrake on by one notch and went for a drive. NO MORE NOISE, Fixed Fixed Fixed, adjusted the hand brake by turning the 17mm nut by 5 turns CW then back CCW by 1 1/2. Handbrake now on 3 notches. Fantastic. Please please all with a rattle ADJUST HAND BRAKE. After 3 months of trying to get rid, finally an easy fix thanks to all who have posted. All the best to one and all.....
  10. #300
    Sep 2011
    France
    I enjoy your enthusiasm. It was handbrake for me too.
