Stroppy Freelander
					My better half's FL throws a tantrum again. The engine warning light comes on intermittently, with a resulting drop in performance as the engine presumably drops into limp mode. Turn off the beast and on restart the warning light is off, until it reappears unexpectedly at some point later.
The other issue is that the vehicle has become difficult to start, i.e it needs cranking over for quite a while before it fires up, even when warm. When enquiring, wifey told me it has been doing this for a while (why she never mentioned anything about it remains a mystery). So far, so good. On investigation today I found that the pre-heating system doesn't work at all (!). So, this explains the starting trouble. The pre-heat dash light doesn't come on, the relay doesn't actuate. The fusible link and the fuses in the engine bay fuse box are alright.
I haven't got any further as time and low temperatures prevented any further investigation and remedy attempts.
Now, where should I start to sort out the problem? Am I right that the engine warning light might have to do with the starting trouble? What is the likely cause of the problem? The glow plugs themselves? The coolant temperature sensor (the temperature gauge works)? Why doesn't the preheating indicator come on at the dash? If the problem is glow plug related, why doesn't the car start easily when warm?
It's a 2004MY Td4, btw.
Grateful for any advice!
				Johannes
There are people who spend all weekend cleaning the car.
And there are people who drive Discovery.
