Results 1 to 10 of 13
Thread: Winch negative power cable run
    Aug 2009
    werri beach NSW
    To all you Defender owners that have installed winches,did you connect the winch negative to the chassis or did you run it all the way back to the battery.
    Quote Originally Posted by skoller View Post
    Back to battery....
    Adelaide - Torrens Park
    Back to the battery is the correct way to do it.
    Jan 2008
    Sydney, West
    I have always found this to be an interesting subject. I understand that you can get bad earths and by going directly to the battery you eliminate this but what is wrong if you get a good earth with 0 Ohms. It costs less as there is less cables you only have one cable to chaff out thus reducing places to short. Elec experts could you please explain.
    Parkerville WA
    I ran mine back to where the main battery lead connects to chassis
    best of both worlds i reckon
    Ian
    Quote Originally Posted by lambrover View Post
    When are you measuring the resistance? With no load or with the full power gong through all of the joins / connections?
    When you run a properly sized cable from the winch to the negative terminal of the battery there are only two possible places for poor connections. At the winch and at the battery. Provided the cable you have used is of an adequate size then the voltage drop will be minimal.
    If there is a voltage drop issue then you only have two places to look for the fault.
    If you rely on the chassis as an earth path you are introducing extra connections which will potentially be high resistance joins. Such as winch to chassis, chassis to earth cable and then earth cable to battery. Possibly even bullbar to chassis depending on the exact earth point.
    Surely it makes sense to minimise the number of electrical connections that are made.
    It will also lessen the chances of chassis rust. To make a good connection you really require a bare metal connection. The bare metal chassis will rust, causing potential structural as well as electrical issues.
    Quote Originally Posted by Brute View Post
    Ian
    Are you using the standard earth leads from the chassis to the battery? If so you are asking for trouble. When LR specified the size of those earth leads I am sure they didn't factor electric winch loads into the design size... How can that be the best of both worlds?
    IMHO the -ve lead should go to the battery.
    Claiming that running the -ve to the battery increases places to short is poor understanding, or mischievous.
    Jan 2008
    Sydney, West
    Quote Originally Posted by Bush65 View Post
    maybe misunderstanding. My angle is that as you run more cable you have more potental for a rub through.
    assuming you had good conections there shouldn't be any differance voltage drop wise between the two methods, I would at least bring the neg cable onto a bullbar mount bolt, or similar. but I surpose you know for sure if it is back to battery.
    Nov 2006
    back to the battery. why take chances on a bad connection
