Results 1 to 10 of 11
Thread: FL2 Silly question
    FL2 Silly question
    Does it have cruise control or just a speed limiter?
    if it does have cruise can someone tell me were to find and engage it
    Ringwood North, Melbourne.
    Hi, you don't have to engage, just get up to speed and press the + button on the steering wheel (top button LHS) and CC will set. You can adjust speed by holding + or - button; cancel and resume by pressing the lower button LHS.
    Hope this helps,
    Rob
    Every Defender owner will get to know Freelanders well, in fact you will learn about all of LRs loan cars, Volvos, Jags and the like. They should use this as a selling point when pitching the Defender.
    Douglas Park, NSW
    Should I tell the boss that you've found the speed limiter on his car?
    Or just the speed warning?
    Whats a speed limiter?
    Dorko
    In the traditional sense a speed limiter is what they have on trucks and Ferraris, the FL2 may have one as well but at a guess may be around the 180km/h mark. I think what Dullbird was asking about is what you see in Commodores, they beep at you when you exceed a set speed by you and the FL2 doesn't have one of these.
    there is a speed limiter on the pug I think...well thats what Ian told me..he said you set it to a speed a bit like cruise control but it does not allow you to go over it as he found out when trying to overtake someone when he forgot he set it
    he said he could not find the cruise control on the pug and then said he thought that the FL2 might be the same....however I thought it very odd for a land rover not to have cruise control hence the question...
    and now I have used it I have an even more relaxing drive to work in the mornings..its so nice having air conditioning that works properly
    I thought the aircon in the new Defenders was quite good? Or is it just a problem with yours hence the loan car?
    Quote Originally Posted by inside View Post
    it was when we first got it then there was a problem that was fixed but it never gets as cold as it used to but garage have tested and said its fine but I disagree...its crap... when on long drives does not cool well at all.
    mikehzz Guest
    I drove a Peugot around Europe and the speed limiter was pretty handy. It took me about 3 days to figure out how to use the cruise control on it.
