Results 1 to 10 of 14
Thread: D2 TD5 Mods Info Request
    Hamish71 Guest
    Gents, FInally got hold of a TD5 at the right price, 150,000k, history unknown. Mods start....now. Need some advice as follows.
    Plan
    "Refresh engine" - headgasket, injetor clean. Is there anything else I should do whilst I am there?
    Intercooler - Any leads on off-the-shelf systems available in Melbourne, or via post appreciated.
    Exhaust - Anyone in Melbourne you can recommend for complete system, including downpipe
    Ceramic coat exhaust manifold - Jet Hot
    Hybrid Turbo - TD5 ALive
    Turbo Boost controller
    ECU reflash - TD5 alive
    LPG - Gastek system
    Longrange tank - Longranger
    Rocksliders - custom...unless anyone knows of some available off the shelf?
    Thanks in advance.
    May 2009
    Perth Western Australia
    Hi Hamish71,
    I have just purchased a D2a intercooler that has a bigger core than the D2, you should talk to Toombie2 off this site re a remap... Done wonders for my Td5 he also has a boost box available and has a VNT turbo he can get hold of...
    Aaron.
    Hamish71 Guest
    WHo/where/how is said "tombie", and any information on the intercooler, spec, weblink, price etc appreciated.
    Ean Austral Guest
    Check the oil pump bolt and fit a coolant level alarm, these should be on the top of your list..
    Check out Triumphroverspares in SA as they have alot of stuff you may require and Phil is very good with just about anything related to TD5.
    Cheers Ean
    99.87 MB
    Quote Originally Posted by Hamish71 View Post
    http://www.aulro.com/afvb/members/tombie2.html
    TRT - Total Rover Tech
    Slunnie
    Adelaide SA
    The infamous "Toombie" is da man when it comes to D2 performance mods.
    His website is www.trt.net.au
    For a D2, bigger intercooler, the one from a D2a is a straight swap & is bigger.
    Toombie does a re-map of your ECU, and has many rave reviews. (Still to get mine - but SOON)
    The exhaust manifold can be an issue, and you need to relieve the stress by grinding out the webbing between the studs.
    Look for an EGR replacement kit. And I would also suggest that you clean the MAF, and check / replace all of the turbo hoses.
    Oil in the ECU harness is another bug-bare with these, but is easily fixed.
    Now, the answers to all of your questions can be found in 2 more places.
    One is a thread called "The good Oil"
    The other is the search function.
    Both of these will give you hours of reading, and will give you answers to questions you dont even have yet.
    Oh, and 2 more things:
    1) Welcome to the fold
    2) Before someone else tells you, the rules of this place are "it didn't happen without pictures" Post some up of your new pride & joy, and enjoy your stay with us.
    Sth Gippsland
    High temp coating is done in Leongatha (160km SE of Melb)HPC High Performance Coatings Pty Ltd, Leongatha VIC 3953 - Manufacturers - TrueLocal
    I'll be honest, to me they are local.
    Hamish71 Guest
    Thanks, have used HPC before as well.
    Quote Originally Posted by Aaron40 View Post
    Hi Hamish71,
    Aaron.
    OI!!!! Wheres my test drive???????
    Plan
    Intercooler - Any leads on off-the-shelf systems available in Melbourne, or via post appreciated. Earlier models benefit from a D2a intercooler, or a complete hi-flow unit is available (I can point you to my manufacturer)
    Exhaust - Anyone in Melbourne you can recommend for complete system, including downpipe Stick with the factory pipe, but replace the centre box with either straight pipe or a straight through box. Nothing over 2.75" is recommended.
    Ceramic coat exhaust manifold - Jet Hot Good move, destress the webbing as well
    Hybrid Turbo - TD5 ALive Nothing but a bigger turbo, the VVT thats available is a better option, they are making a new batch now.
    Turbo Boost controller This is not a TD5 alive part. But they are good
    ECU reflash - TD5 alive I can help you here
    LPG - Gastek system Not worth the extra weight (you'll ruin your load carrying capacity and exceed GVM to easily) the turbo/ecu will do.
    Longrange tank - Longranger Not a bad option, but consider a belly tank (more capacity for your $$$)
    Rocksliders - custom...unless anyone knows of some available off the shelf? Contact Simon at 4x4 intelligence for off the shelf or make your own
    Thanks in advance.
    See notes above...
    Is it Auto?
