Thread: Later S1 diffs
    Loganlea Qld
    Later S1 diffs
    Were series 1 diffs any different to those on S2s and S2as and if so when did they change. Need to know as we seem to have a pretty drastic oil leak in one and happen to have a S2 diff lying around spare.
    Glen
    1962 P5 3 Ltr Coupe (Gwennie)
    1963 2a gunbuggy 112-722 (Onslow) ex 6 RAR
    1964 2a 88" SWB 113 251 (Daisy) ex JTC
    REMLR 226
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    They're 4.7:1, the same as later ones and I assume they fit. Not a great deal of help am I.
    Numpty
    REMLR No 143
    Nov 2006
    Wollongong NSW
    Apart from the VEP long nose diffs they are all the same
    S3 rover diffs fit but be careful you have one for the rear with the fill plug in the housing. Later front diffs didn't have a fill plug in the centre housing.
    A trifle hard to fill with oil......... S2 diffs OK
    Loganlea Qld
    Thank you very much, will try and see what happens. Can only be an improvement at the moment.
    Glen
    REMLR 226
    JDNSW's Avatar
    The above information applies if you are talking about the differential, but not if you are using the term differential to apply to the whole axle.
    Apart from early 80" and Stage 1 diffs all the Series diffs are interchangeable if not identical.
