Thread: Entering radio code in 2008 puma radio?
    Київ
    Hi I have a 2008 puma 110 csw, the dealers replaced the clutch and somehow stuffed the radio code
    When I press the power button it gives a message after about 2 seconds of: 3cde err then goes to safe
    I found two radio codes in the stuff I got so someone must have replace the radio and not put it in the dealers network system!!
    How do I re enter the code? any help appreciated
    Maleny, Queensland
    Pull the radio out of the car and hit it three times, very hard with a large hammer. Turn the unit over and repeat.....
    Then go and buy a decent radio to replace it.
    Jul 2003
    From the Owners Handbook
    Audio system security
    SECURITY CODE
    The security code is entered into the head unit
    during manufacture; it is not necessary to enter
    the code during normal vehicle usage.
    However, in the event of a battery reset, e.g.
    subsequent to a flat battery or head unit
    change, the head unit will prompt for a security
    code by displaying
    CDE 0000. Following an
    interruption in power supply (battery
    disconnect for example) ifCDE 0000 is not displayed, pressing button
    5 will display the code entry screen.
    Entering a security code
    The vehicle is delivered to the user with a
    security code card; the user must enter the
    code using the numeric (radio preset) buttons
    to resume operation of the head unit. Preset
    buttons 1, 2, 3 and 4 correspond to each digit
    of the security code. For example, if the code is
    6789 the user must press the number 1 button
    six times, the number 2 button seven times, the
    number 3 button eight times and the number 4
    button nine times followed by a single press of
    the number 5 button to complete the code
    input process.
    If an incorrect code is entered
    1CDE ERR will
    be displayed and you will be asked to re-enter
    the code correctly. If the code is entered
    incorrectly three times
    3CDE ERR will be
    displayed after the third incorrect entry,
    followed by SAFE. The audio unit will be locked
    into safe mode for one hour during which time
    it will not operate. The audio unit must be left
    switched on for one hour. Once an hour has
    past with the audio unit switched on, the
    correct code can be entered.
    In the event that the head unit code card is lost
    the user should seek advice from the dealer to
    retrieve the code for their head unit. The user
    will be required to produce some form of proof
    that they are the rightful owner of the vehicle
    e.g. the log book or a purchase receipt (if
    bought second hand, for example) before the
    dealer is authorised to issue the code. This
    condition is imposed to prevent stolen head
    units being used.
    Mahn England
    Ex 300Tdi Disco:
    Київ
    thanks so much, all sorted out!!!
    Jun 2007
    Margaret River
    Enter radio code with 5 not RND
    Quote Originally Posted by one_iota View Post
    The PDF is here:
    http://www.aulro.com/afvb/local_link...&catid=7&id=80
    HTH
    [/LEFT]
    Yesterday I disconnected my battery PUMA 2012, and needed to reenter the security code. Followed the instruction in my handbook which says to complete the entry with RND button (not 5). This didnt work so finally after a few stabs in the dark got it to accept by pressing button 5. Just like it says in the quote above.
    So dont believe everthing you read in the handbook.
