No.
Not with LR's SDD system.
Only Factory sizes.
I know that you can program tyre sizes into the D3 & presumably D4.
My question is if this only works with the standard LR tyre sizes i.e.
235 x 70 x 17, 255 x 60 x 18 or 255 x 55 x 19.
Could you theoretically program in 265 x 70 x 70 & thus correct the speedo with out detrimentally affecting any thing else?
Chuck
No.
Only Factory sizes.
I have programmed 265 70 17 tyres into my D3 and readjusted the speedo to read accurately using my BBS faultmate
RichardK
Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
Richard
Thanks - any other effects other than correcting your speedo?
Could you describe the process albeit simply.
Chuck
Connecting the Faultmate server to my OBD socket, and reading the car configuration data through the vehicle explorer program, inserting new data for Rim size, tyre size, aspect ratio and dynamic rolling radius then writing that information back to the ECU.
Then checking the result against my GPS and making adjustments to the dynamic rolling radius until I get the GPS and speedo to agree.
All quite simple, took about 15 minutes.
RichardK
