Results 1 to 10 of 33
Thread: Clearing D4 aux battery tray
    NSW SW Slopes
    Here's what I did to relocate the control modules occupying the D4 aux battery tray.
    The transfer case ecu was removed from its plastic cover. The ecu is still unsealed same as in the D3 and the cover only prevents dust or water from spilling onto the ecu but not from entering the cover from the bottom. The glow-plug ecu was unbolted from its metal bracket. Both the plastic bracket/cover and the metal one were not re-used.
    The alarm horn bracket was temporarily removed and the short horn bracket removed from the main bracket. The wings on the main bracket were flattened (more or less) and an unused bolt stud was cut-off.
    The TC ecu bolts directly to the flattened horn bracket using existing holes. 2 bolts and nuts are required.
    The horn is bolted under the lower brake line bracket bolt using one of the longer bolts from the discarded plastic TC ecu bracket, along with a spacer between the short horn bracket and the brake line bracket giving clearance to the turned-up edges of the brake line bracket.
    The main horn bracket now with the TC ecu attached is refitted to its original position. Some additional insulation tape was used on the wires close to the connectors to prevent possible chafing on the metal bracket.
    The glow-plug ecu is bolted through the hole in the engine side of the box where an unused white plastic clip was fitted. It requires a washer.
    The large harness connector was temporarily unplugged to remove twist, then the harnesses and connector cable-tied into a group.
    The brake lines from the modulator were rotated upwards a little by very slightly loosening the nuts as 1 pipe intruded into the battery space.
    The plastic ribs at the bottom front of the tray were removed using an angle grinder. The plastic spacer along the engine side lower edge will also have to be removed to get clearance for a 175mm wide battery.
    You were a busy man this morning (8:57am)
    Cheers Mate.
    NSW SW Slopes
    Early morning jobs were done so time for some quick distraction playing with the D4 then do the write-up during smoko before the day has a chance to disappear.
    Feb 2010
    Mount Martha
    Hi Greame, thanks for the info & pics. I had my auto electrician do a similar thing to mine with the fittment of the second battery. I have printed off your photos and intend to show them to see if they did they same thing.
    Sydney, Australia
    Good job Graeme.
    I thought it could be done.
    Now why didn't Land rover do that.
    They could even make money making it an option.
    If they did that and designed the calipers smaller, at least for the Aus market they may well have got all the 4WD mag awards again.
    Graeme, I would seal the module. Cover the back with some bitumised tape and speay the rest with CRC Plasticote.
    NSW SW Slopes
    Quote Originally Posted by CaverD3 View Post
    I plan to seal it, but having only blue sensor-safe silicon on hand I thought I'd get some neutral-cure clear so it doesn't stand out so much.
    Feb 2010
    Mount Martha
    Hi Graeme, checked out my set up today. Pretty much the same as yours except that the silver box thingy (I'm a builder not a mechanic) is mounted against the side and the horn is mounted behind the radiatior. I noticed that the battery they have used has side mounted terminals, not at the top like most batteries. This allows the original plastic cover to be fitted back on. Interested to hear a reply. Cheers, Craig
    NSW SW Slopes
    What's the battery's Ah capacity? Mine is 80 Ah and has recessed nuts rather than posts but is still too tall by about 20mm.
    Feb 2010
    Mount Martha
    Hi Graeme, mine is also an 80 Ah. I have just found out that the battery is a dud as it is not holding charge, so my auto elec has ordered me an 'Optima' battery also with side posts. He highly recommends this battery.
    mandurah
    Quote Originally Posted by Disco4SE View Post
    Hi Disco4SE. I recall you had some pic's when your tray was cleared. Can you provide the detail on the posting ? I can't seem to locate it. I still favour fitting the second battery in the old D3 location, and would like to compare the two that have been cleared so far.
