Results 1 to 3 of 3
Thread: 02 110 Ride Height
    02 110 Ride Height
    After trawling the forum I will probaly upgrade the 110 Front springs as we have a bar and winch fitted.
    Currently , measurements from ground to underside of wheel arch flares at the top is ;
    Rear 910mm
    Front 845mm
    We also have an Outback drawer system fitted so when loaded will the ride height be right at 845mm front and back
    What is the normal ride height dimesnions as outlined above
    I continue to learn about the new Fender
    Pete
    North Central Victoria
    Pete,
    I have an 04 defender 110 with a winch and bullbar. I put the standard 130 springs on the front to level out the height. They are great - the standard 130 springs are more heavy duty than the 110 ones and only cost around 100 bucks a corner. I have gone down the path of using one of the aftermarket guys and had nothing but problems. I changed back to the 130 spring and have been extremely happy. Go original where possible I reckon.
    In regards to the rear, I have had custom springs made up to deal with the specific weight loads that I carry (I tow a kanga camper trailer etc). I think this is the way to go - it is much less complicated that putting air bags etc in the back to level the rear - ie much less to go wrong in the middle of nowhere. And I know that this is not original but the original springs could not deal with the weights I carry. Again this is around 100 bucks a corner. Go for billstein shocks and a steering dampner if you have the cash - awesome combo .
    Sorry I dont have exact measurements etc but Im sure you will get plenty of replies from people that do!
    Aug 2008
    latrobe valley victoria
    Quote Originally Posted by gusthedog View Post
    Pete,
    front on my 2002 with winch and 130 springs is 910mm to guard ...rears are curently at 955 mm {i recon to high for my shocks}
    late i know but for others it might be helpfull
