Quite normal. No power unless ignition is at least on Acc.
Designed to stop you draining the battery. Get a Taxside system and second battery, you can wire it to the rear socket.
Hi All,
Just went to plug my mini waeco in the back of my D4 and when the car is off i get no power.... correct me if i am wrong but what the? My FL2 always stayed on and it was great because it meant i always had a cold drink in the car.
Is any one else got this problem? If its standard can it be re wired or something?
Dorko
I remember reading about this last year on this forum. On RAVE find the relay that controls the power feed to the outlet. Remove the relay and fit a jumper wire from terminal 30 to terminal 87. Keep the relay handy so you just plug it back in for standard.
Hi bee utey,
There are no RAVE manuals for D3/D4.
Dorko,
Look in the manuals that came with your vehicle.
Best Wishes,
Peter
Yeh the manual says bugga all about the power sockets.
I spoke to LR this arvo and they said the same thing, it design that why as it a proper 4WD....(I think he was hinting my FL2 was not) and i should get a second battery fitted to the D4....
I was like sure but i thought it couldnt fit, but LR confirmed that ARB is in vibrating testing with a new bracket and should be here next month.
Hopefully this is trueI miss my cold drinks in the back....
Dorko
Dorko,
I think that you are wise to consider fitting an auxiliary battery. The trouble is that LR in their wisdom have decided to use what was the aux battery spot in the D3 for other items in the D4.
I have heard of others shifting this "stuff" around in the D4 in order to make space (but I must admit that I'd hesitate to do that while under warranty.
Drivesafe (Traxide) has investigated fitting the aux battery in front of the starting battery, but (IIRC) concluded that it was too hot for the battery. He has instead designed a system where the aux battery is in the rear of the D4. Look here:
http://www.aulro.com/afvb/verandah/9...ery-kit-2.html
From it, you can see how new this system is.
HTH,
Peter
Apartently ARB is makign this bracket to go in the engine bay, next to the wiper filler.
I just open my bonnet and yes there is a big-ish gap.
Am i missing something?
Dorko
Hi Dorko, I have had my second battery in for 11,000Klm's now and haven't had a problem. My auto electrician left the original 12 volt socket where it is and put another beside it that runs to the second battery.
Will send photos through soon
Hi Dorko,
I noticed that once you unlock the vehicle with the remote, these aux sockets go live. I have no idea if they time out or stay up. Obviously not much good if you are not around the vehicle.
The Traxide kit for the D3 gives you the option of installing a new 12V plug, with a feed from the second battery, or connecting the existing rear plug into the circuit. The remote D4 kit, has plugs on the battery pack.
