Results 1 to 10 of 21
Thread: cdl dash light
    Mar 2010
    gold coast
    cdl dash light
    2000 D2 v8 manual, When i engage the cdl no light comes on, on the dash moving or not, the cdl is engaged and working ive read all through the good oil and other searches on the forums, how do i make it work?
    Thanks,
    Jason.
    Oct 2007
    Brisbane West
    I have the same model with manual and have just done a retrofit of the CDL. Give us some more info - does yours have the spiggot for CDL and have you just activated it...does yours have the CDL switch ont he output housing?
    Australia
    Check your connector plugs on the Transfer Case.
    cheers.
    Mar 2010
    gold coast
    Hi Oscott, Yes it has the spiggot and it is connected to a home made leaver that runs to the drivers side body rail so i can turn the cdl on without climbing under the disco, i have used the cdl a few times driving some of the tracks with the gclro club, i dont know about the switch on the output housing.
    Strangy i dont know about that switch, what does it look like and where is it located on the housing.
    Thanks,
    Jason.
    Oct 2007
    Brisbane West
    Jason - it is on the front of the output housing. White connector block. There should be two - one for low range/high range and one for CDL light. Just crawl around the front of the transfer case output housing with a torch. For now just slip off the connector blocks spray some contact cleaner in them and slip them on and off a couple of times to clean and then back on again.
    Mar 2007
    Tarneit VIC
    I didnt know there is light for low/high range? I have the cdl light not low/high range. What does the light look like?
    Australia
    Quote Originally Posted by dearot View Post
    No light for High and low. The switch however is to tell the ECU that you are in Low for HDC and fuel map.
    Mar 2009
    Port Stephens N.S.W
    No, light is for CDL (1 x switch)
    The second switch tells the ECU wether the box is in high/low range ... no dash light.
    Kev..
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Oct 2007
    Brisbane West
    as per above matey. The second switch - hi/low feeds to the SLABS computer. Unless the computer knows that you have selected low range it will not allow you to use Hill Decent Control and lowers the urgency and aggressiveness of the traction control - but no light on dash. You know if it is working cause HDC will continue to chime when you hit the button even when in low range...normally just dirty contacts in that switch and easy to clean.
    Mar 2010
    gold coast
    Ok guys just an update, ive climbed under and had a look around and found this-
    male to female plug unpluged, closest one to the spiget.
    blue/yellow & black wire going in a white plug and colours out are pink & white, this is cut and taped up, not sure what this is for?
    Connected male to female plug, turned ignition on and the cdl tc and abs light comes on, no mater what id do they stay even what cdl is not activated, from car stop or start, do the other 2 wires have something to do with this.
    How can i fix this to make it work like our d2a?
    Thanks,
    Jason.
