Thread: Whirring Noise under Accelleration!!
    Kingaroy, Cairns and Brisbane
    Hey guys,
    I have a whirring noise, when my car is under load, sounds like gears meshing without oil, I have checked all fluids and levels...all good. any hints as to where to start looking?
    So this noise only happens when i am accellerating, sounds like its under the car too, Also i have changed the tyres so its not road noise from my muddies??
    Ryan
    Jan 2008
    Medowie, Port Stephens and Sydney
    I've recently had a slightly similar experience that sometimes sounded like i was driving over the freeway edge ripple strips. Tightened up the suspension as an aside and it seems to have disappeared. Hope i haven't just hidden a problem.
    Worth a go though.
    Nov 2008
    its not diff wine man,,, like back lash gone out
    Hey Stig, yeah man its whining pretty bad, i got use of a hoist on saturday so i might get under there and fiddle with a few things, gotta get it ready for my new bullbar (FRIDAY!!! HRA are AWESOME!!) and i am booked for my DARE on Sunday. So ill see what I come up with???
    If the whirring is coming from the front it may be a bearing in the transfer case...possibly the front bearing in that part of the case which houses the viscous coupling. One way to verify this is to remove the front drive shaft and try and 'wobble' the remaining part of the UJ coupling on the front of the transfer case...it should have only very minimal if any, up/down/side-to-side free play.
    The other alternative is the front diff.
    Take it for a drive minus the front drive shaft and see if the whirring is still there under light acceleration... if not then it's possibly either the t/f case bearing or the diff...
    Good luck
    Hey Hoges!!
    Cheers mate ill give it a go!!!
    Hey if your in brisbane, ill be in brissy tomorrow afternoon (friday) if you would like to meet up for some jam and scones ( sorry range rover talk for a beer) just text me your address my number is 0422616212, would be great to swap storries...
    Cheers mate
    Ryan
    Nov 2008
    oi man,, how you go with the front end,, herd you rung and talked to pual,,, wasent in soz man,
    Hey Stig...
    Nah it was all good mate, started gettign the thing a part then the beer kicked in and had a fight with the missus...result...hmmm range rover didnt get touched...oh well ill tempt fate pull the front prop shaft off on saturday, although i have to pick up my front bar tomorrow...hmmm dilema
    Aug 2009
    melbourne
    Diff noise
    Hello there,
    Just letting you know that I have whining in my rear diff. happens under load and less when coasting.
    Apparently the hard facing on the crown gear wears off causing the noise.
    It ends up being a replacement of the diff center as the metal bits end up damaging other parts of the diff as well. It is also suggested to change the bearings at the same time. On replacement you will get no further problems. Or so I am led to believe.
    My next course of action is to fit a locker to the rear anyway so I will wait until I have the readies to do this.
    Yeah I have already got my locker sitting here!!!
