Results 1 to 9 of 9
Thread: 2.5cm long 35Amp fuse
    Qld.
    Heya Folks,
    I'm having no luck finding the right fuse for Matilda - it's 2.5cm long cylinder type - 35 Amp.
    Anyone got a clue where I might find some?
    2007 Defender 110
    1993 BMW R100LT
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    Standard glass fuse, I thought. Should be available at any parts place, eg Supercrap.
    Numpty
    REMLR No 143
    Qld.
    Quote Originally Posted by numpty View Post
    Yeah - but they aren't - not 25 mm long. They have shorter and longer ones.
    2007 Defender 110
    1993 BMW R100LT
    Cessnock NSW
    I would try KB classic parts out at maleny or any of the swap meets, cheers Dennis
    Yass NSW
    These blokes have lots of glass fuses but they arent 25 mm, 22 or 27 seem to be closest
    http://www.wagner.net.au/catalogue/02_Components.pdf
    Click on the fuses section, page 23
    Regards,
    Tote
    JDNSW's Avatar
    These are not easy to find - the last ones I got came from Tandy a few years ago, so perhaps an electronics place might be the go. Otherwise an older long established auto electrician or a specialist in English cars.
    That fuse.
    The holder should be able to take a standard 3AG type at 35Amps, measuring 1 1/8 inches. In metric sizing, that would be the 27mm. version.
    That is what I have done with my Ser 2.
    If you want to get more exact, salvage the old fuse carcase, carefully unsolder the wire from a new one and transfer it to the shorter tube and ends. This would require steady hands, some fine pointed pliers and a 40w iron or bigger - up to say 80w.
    Rovers4.
    Last edited by rovers4; 23rd April 2010 at 08:03 PM. Reason: Be careful not to overheat and melt wire.
    Qld.
    Thanks chaps - appreciate all your considered advice. Gives me a few good pointers.
    2007 Defender 110
    1993 BMW R100LT
    Fuse
    Hi All
    I solved the fuse for the fuse box
    by wining some bare copper wire around the glass and soldering the end to the end cap
    fits perfect
    save a lot of worry
    with the cap on the rivet counters do not know the different
    Ian
