AFAIK the 110 drum housings are the same. The difference is in the hubs and stubs. I can measure a drum housing if you want?
 ForumSage
						ForumSage
						hey all,
first off, im looking for a bare Sals Disc rear housing.
second, does anyone have an exploded diagram of the rear axle flange/stub axle/hub/brake assembly?
does anyone know the thickness of the flange on the end of axle case?
cheers,
Serg
I am planning on doing a disc conversion on a sals axle. A forum member kindly gave me a copy of the parts diagram for the army 110s. The only difference was the part no for the hub which is now unavailabe. I was going to try using the original hub. The uk wolf disc conversion is another option.
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
 ForumSage
						ForumSage
						This might be of help..
Drum brake 110 salisbury disc brake conversion - LR4x4 - The Land Rover Forum
Easy enough to sign in - good tutorial
 ForumSage
						ForumSage
						thanks DeeJay,
good pics there for me and will help those doing the disc conversion
cheers,
Serg
This is a series sals, but I am 99% sure they are the same.
Flange OD: 131.5 mm
8 mm thick
Tube: 80 mm OD throughout (series and 110)
67 mm ID at flange - but only 5.6 mm wall in middle - maybe tapered?
Disc converted 110 sals. Will take measurements on w-end if different.
 ForumSage
						ForumSage
						thanks Ben,
thats what Ive been looking for.
Serg
