Results 1 to 10 of 17
Thread: FL2 - Reduced Engine Performance...
    Uh oh....
    The FL2 let us down for the first time last night.
    My Mum (who I sold the FL2 to) was driving and noticed it had no acceleration and then when she stopped and restarted it there was a message on the screen "Reduced Engine Performance".
    RACQ couldn't find anything wrong so we managed to drive it home as it will drive quite happily at any speed it just got no acceleration at all.
    Going to get a tow truck to take it into Austral this morning.
    06 SE V6 Discovery 3
    The ECU has detected a fault and switched to default settings - commonly called limp home mode.
    Hopefully just a clear of the codes will fix things or maybe just a dud sensor. Unlikey to be more serious stuff.
    I have had it twice on my FL1 - first was a failed fuel temp sensor and the second was some crude in the fuel shutoff valve - the ECU codes pointed me to the right direction in both cases. While the check engine light was on the car drove like a dog bit still ran - not a lot of acceleration.
    Douglas Park, NSW
    It could be anything but there's only one bulletin that I could see quickly that might be the problem & it's a software download for the turbo.
    Fault code P0234
    Apr 2010
    I had a similar issue with my Peugeot 407. After the dealer ended up replacing numerous components over a period of time - the actual fault was the battery! It seems that some European cars a battery that is not 100% will cause these types of issues to arise with the ECU.
    It was strange that it too so long and so many replaced parts for the mechanics to suss out the actual problem and an easy fix.
    This may not be the cause of your problem but it could be worth mentioning to the mechanic?
    Good luck,
    I've only heard this second hand but the problem was with the turbo and it required a software reset.
    Sounds like it might have been the issue Scouse mentioned... or possibly what Yonjuro mentioned as a new battery was installed just before the problem appeared.
    I'm wondering if when the new battery was being fitted they didn't let the computers shut down fully \ shorted something out they shouldn't have \ didn't perform the correct ritual scarfice to the appropriate gods etc and buggered something up.
    Anyway its seems all is good now.
    Last edited by djhampson; 29th April 2010 at 02:41 PM. Reason: Edit getting my words mixed up....
    Quote Originally Posted by djhampson View Post
    So you have it back from the mechanic? or it fixed itself?
    If at the mech - what did the test book indicate?
    Its being picked up this afternoon...
    I'll try to find out more info.
    Well we've got it back but the turbo doesn't sound right at all..
    Heres a really bad youtube clip but you can hear the whine of the turbo really clearly and when you back off the revs there is quite a blow off noise...
    Is this normal?
    [nomedia="http://www.youtube.com/watch?v=-h2wlxqlx-E"]YouTube- Freelander 2 Turbo Noise[/nomedia]
    Mine doesn't sound like that.
    Wouldn't be unusual for Austral to have stuffed something up. I swear they never test any of their "fixes".
    Sounds awesome! hahahha....
    i had this on my XR6 turbo... i was driving it pretty had just before i traded it in and i blew off the air intake pipe.
    Sounded just like yours!
    Dorko
