Originally Posted by
ADMIRAL
Hi Connock. More data required I think. Where is the tank located ? If it sits higher and is purely gravity feed, your OE fuel gauge will just read full for longer, and once the fuel from the reserve tank has drained out, you are back to a std setup and fuel readings.
Others may be able to advise if the fuel gauge can be recalibrated, I suspect not. I cannot see any practical way it could work. It will likely be linked to a sender in the main tank, and as such can only read what is in that tank.
