Results 1 to 3 of 3
Thread: What is the amperage of a 1999 TD5 Alternator?
    Jan 2010
    Mount Eliza
    I wanted to buy a Dual Battery setup today, but apparently there are different versions depending on the amperage of the alternator. I have checked the Rave CD but it is either not there or (quite likely) I missed it.
    May 2003
    On The Road
    Mines 130,,,
    I imagine they are all the same,,,??
    it is written on the top---
    Bacchus Marsh Vic.
    Quote Originally Posted by DCPAus View Post
    From Haynes manual...
    Nippon Denso 120 Amp.
    13.6 to 14.4 Volts @ 3000 Engine RPM..
    Hope this helps
    I use a Redarc SB112, 100 Amp isolator solenoid with no problems.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
