Results 1 to 10 of 29
Thread: Diff Guard or Shovel?
    May 2008
    I fitted a Bearmach front diff guard... you be the judge
    Clearance has been reduced by approx 20mm.
    It is simply attached to the existing diff pan bolts. You can see that the nuts don't complety locate on the threads. I wouldn't trust them to hold on impact.
    Cheers, Paul.
    I think it needs a support bracket up the front and over the diff - like the QT rear diff guard.
    May 2008
    Yep, totally agree Ron. I also needs to sit a lot closer to the diff pumpkin so clearance isn't so badly affected. Think mine was 250mm before fitting and 230mm (or 270 to 250) after fitting, and that's with 33" tyres, so maybe about 180mm clearance on a stock P38.
    You could fry an egg on that!
    Shovel.
    I think you are right, Paul. If that hit something the wrong way, it would bend the studs back or strip the nuts off. And as the studs are inserted from within the diff casing.......
    Nov 2008
    hope you dont mind honest opinions, it looks ****
    it doesnt look strong and in reverse its going to be a deep riper,, hope you dident pay to much for it
    May 2008
    Quote Originally Posted by stig0000 View Post
    I'm shattered yeah it does..
    Paid enough to learn that I can build a better one for a lot less and stronger. My P38 is owned by my business (no, not Hard Range... the other one that makes money and pays my mortgage) so this is a tax write-off that I will get charged FBT on anyway... so I guess it did cost me a lot
    Cheers, Paul.
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Thanks for taking one for the team. I now know what I won't be putting on the back diff!
    Seriously ordinary design.
    Aug 2008
    Wagga
    Aug 2008
    What other diff protectors did you look at and choose this one??
    Steve
