Just as a further update, I spoke with Hastings Deering lab today regarding the wear metals, and these are their comments...
1. Extremely high copper & tin reflect wear to bronze thrust washers or bushes
2. High iron is from wear on gear teeth
3. Case hardening on bearings has started to wear off (chrome)
4. Extraneous contaminants are not significant. So dust entry is not the problem
5. Low oil viscosity indicates thermal degradation of the oil. That is consistent with my observations of the transfer running too hot, from brand new.
6. The visible wear metals of 2-3mm size are unacceptable and indicate a problem.
The point mentioning all this is that if you have a Puma, and the floor and seat box panels get pretty hot on a long run, it's possible you may have a problem similar to mine.
At any rate, it's worth checking the quality of the transfer case oil at every service. The oil change period is down for 80,000kms, which is too long for me to feel comfortable with. And this one was bad at 40,000km on the oil. )The lab tech has found that for his 80 Series cruiser, 20,000km in optimal for the transfer case.)
  ) Originally Posted by Brid
