Thread: 130 d/c tray size?
    May 2009
    north hobart
    130 d/c tray size?
    can someone tell me what the size of a standard tray is on a 130d/c and also what would be the longest tray you can fit? also the draws under a tray. are they water tight or not?
    any help would be great thanks
    Feb 2010
    Victoria
    Quote Originally Posted by tas130 View Post
    I will be opting for a 2200mm on mine....................one reason why I bough ta 130 Dual Cab as its the only twin cab have a good sized tray on.....other than a F250/350/450
    Balgal Beach
    direct from the MY10 brocure, load bed area is 1668 x 1670 (L x W)
    ant
    Logan Village area S.E. QLD
    or go to the thread that pc3 started to see all the options
    With 130 Dual Cabs can you have longer trays than Hilux dual cabs etc. ?
    Mrs hh
    Series Landy Rescue
    Our FB Page..
    Nov 2007
    Wodonga Vic.
    I placed a 1800 x 1800 steel tray on my new 130 d/c having it 1800 long gave me 500 mm over hang from the end of the chassis to the end of the tray.
    This worked out well with tow hitch as i don't have to lean under to connect the hitch.
    I also gapped the tray from the back of the cab so I can fit a filler for the new long range tank I'm building.
    As for the width I looked at the widest part of the defender (guard extensions) and sat the tray just behind that width.
    Allen
