                                                26th May 2010, 06:34 PM
			Humble radiator cap.
 I recently posted my experience in relation to a professional radiator rod/flush alsp a post with a leaking fuel cooler.
 After  nipping up all the clamps I found that I was losing coolant from the coolant reservoir.
 Initial thoughts were pressurising and head gasket and $$$$$$$
 I remember reading another post about the humble radiator cap and where replacement of reservoir (=radiator )cap and the problems was solved.
 So $28 later and the problems seems to have been solved.
 Now I’m not suggesting that the radiator/reservoir cap is the solution to all coolant loss. However if in doubt it’s certainly worth replacing the cap as a first step and see if that stops the coolant loss?
                                                26th May 2010, 07:40 PM
					Scott, Where did you go for your radiator cap I got one today from Land rover in Melbourne for $19.50 Also agree with cooling loss or overheating problems start at the cap and work down. I'm glad i only paid 19.50 now I have to get a top hose which will be more$$$ Andy Also agree with cooling loss or overheating problems start at the cap and work down. I'm glad i only paid 19.50 now I have to get a top hose which will be more$$$ Andy
                                                27th May 2010, 07:13 AM
