Thread: Stage 1
    wraco50100450 Guest
    Stage 1
    Iam considering wrecking my Stage 1, is there any interest in the drive line? I have a maxi drive front end and Detroit locker in the rear. Up rated transfer case and centre dif with 1:1 top gear
    Rangier Rover Guest
    Quote Originally Posted by wraco50100450 View Post
    Yes, but, some one closer will likely take them off your hands.
    The diff stuff would be great for my old series 111 109 with the pegged 4.7:1
    Does the transfer have tapered bearings on the idler?
    Aussie Expat in NZ
    If I could somehow get the Maxi Drive into my county then that would be a big yes. I assume it is the MD locker, not just the axles?
    Dec
    Hay Point
    Let me know what you want for the gearbox/transfer if you go ahead with wrecking it..
    Cheers......Brian
    1985 110 V8 County
    WA
    Quote Originally Posted by flagg View Post
    Dec
    The centre, locking dog and actuator will all fit. You would just need to buy some new (longer) axles from HTE (also assuming it is a complete locker).
    I could be tempted with the front Maxi setup for our stage 1
    Aussie Expat in NZ
    Quote Originally Posted by Psimpson7 View Post
    I'll fight you for it!
