Results 1 to 10 of 19
Thread: Whats the best Chassis for a project vehicle?
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    Following on from statements in my Disco chassis/ Fender ( Dakar/ Bush Rangie style) bodied kit car got me thinking. Where is the best place to start for we project builders. Hopefully this can become a 'Rough Draft'for builders to sort the BIG question about their builds.
    So, What IS the best chassis to go for?
    Please comment on :
    1.Availability/ Price
    2.Ultimate Strength/ flexibility
    3. Rarity and hence intrinsic value to a restorer (Leave the 88', 100'&109's for the restorers!)
    4. Price availability or components to suit (Axle swaps/ upgrades)
    5.Ability / ease of modification for different bodies
    6.Best application for different lengths, eg Winch, Outback Challenge, Ramp-overetc
    7. Other stuff I hadn't considered...
    Cheers, Dave.
    Last edited by Barefoot Dave; 17th June 2010 at 12:38 PM. Reason: Additional thoughts
    Jul 2008
    Cessnock NSW
    this will be an interesting thread
    all i have to say is from what i have seen is that out of any 4wd (not including the exotic 4wd's and unimogs etc etc) land rovers have probably the biggest,well designed and strongest looking chassis out of all of them land rover also offers alot of sizes for different tasks such as 90",110",130"(127") so on and so forth to be suited to certain tasks.
    if you wanted a rock crawler i am asuming (being a land rover man) getting a 90" due to it having less length which will make it less likely to belly out but thenagain with a bit of a lift it will also be less stable than a 110 or 130 i would think so thats where you get portal axles , greater offset rims , bigger tyres and setup suspension so that it doesnt sit 50million inches of the ground (hence meaning more unstable) but give the suspension more flex/droop etc etc (lift isnt everything)
    all depends on the exact purpose i suppose
    there is also a place in south australia (i think its in south australia) that sells new galvinsed land rover chassis which would be the go think they were around the $3000 mark though
    99.87 MB
    I think most of the rock crawlers, buggies etc are somewhere around 100-110" and generally on the longer side of within that range. The 110 chassis is a deeper section chassis and so probably stronger chassis than the 100" chassis. For that type of thing I think the Defender chassis followed by the Discovery/Rangie chassis is the go.
    Slunnie
    Rangier Rover Guest
    I would think the 100" Rangie or Disco would be the most popular as plentiful and cheap. Some comps are set up to catch the 100" out though.
    The 100" chassis needs to be braced for serious off road use.
    I had a look at the bush Ranger kit a wile back. Bit expensive for a highly impractical vehicle I think.
    Oct 2008
    Great start, fellas. Thanks for the input.
    Quote Originally Posted by Rangier Rover View Post
    Exactly, Hence my interest in this particular kit (NCF Sahara), heaps cheaper and easier to build by the looks.
    in the wild New England, NSW
    D1 & RRC chassis are probably the cheapest coilers....one thing to keep in mind if it is to be road-registerable is that it is easier if the chassis doesn't come from a write-off
    Oct 2008
    87C, thanks, that was what I thought.
    The tricky bit will be to get a repairable right-off with a (relatively minor) rear-end shunt for what I have in mind.
    No small order ; /
    Rangier Rover Guest
    Quote Originally Posted by Barefoot Dave View Post
    They're great if you want to do a kit. Be the one I'd go for. You end up with a multipurpose vehicle at the end.
    You really need an update Disco that had a light roll over etc. They come up cheap and have good running gear.
    This is what you have in mind?
    http://homepage.ntlworld.com/m.scruton/sahara2.html
    Goolwa SA - but top ender forever
    Exactly, Hence my interest in this particular kit (NCF Sahara), heaps cheaper and easier to build by the looks.[/QUOTE]
    can you post a link so we can see what you have in mind?? (may give me some insparation)
    Oct 2008
    G'Day Blitz
    The thread on the project I have in mind is here:
    'Fender body+ Disco chassis= <:^ )))))
    Cheers, Dave.
