Results 1 to 10 of 12
Thread: 95 p38 vogue, dog chewed key
    Rove Brown Guest
    Hi just took onership of a RR p38 and when i picked it up the previous owner handed over both keys, but told me the remote key was chewed by his dog and didn't work any more.
    May 2008
    that sucks, how badly is it chewed? if the PCB is intact you "might" be able to get a cheapie remote off eBay or from a wreckers and replace the PCB.
    Cheers, Paul.
    Mar 2009
    Bexley NSW 2207
    did you only get one remote with the car? they should have two and a spare normal key. if you are in the Sydney area give me a call i may be able to repair your key or clear the BeCM and program another key.
    you can get me on 0421 509 083
    regards
    Rupert Prior
    Quote Originally Posted by Rupert Prior View Post
    I'd like to know how this is done as all information thus far indicates it is impossible to program another key to an exisiting BECM. (I need a second key, too.)
    Mar 2009
    Bexley NSW 2207
    i repair auto electrics for a living and specialise in landrover but i can do most european marks. i can cleanout the becm and reprogram to a new fob code (i have to get bar codes translated to fob codes).
    May 2008
    Rupert, you sound like a very useful bloke for us all to know
    Can you do keyfob renews (resolder buttons, contact etc) like the link Ron posted above? and if so, what sort of price please? Bexley is a lot closer than the UK.
    Cheers, Paul.
    Mar 2009
    Bexley NSW 2207
    hi Paul
    yes i can test units for correct frequency, range, refit buttons, battery connectors etc. cost to refit buttons with a new cover and clean up would be about $40-$50 plus postage. if it is not repairable i do not charge.
    regards Rupert
    May 2008
    hi Paul
    regards Rupert
    Hi Rupert - sounds fair to me. Both of my keyfobs work, although sometimes a bit intermittently. I have replaced the batteries, battery cover, and button cover. Suspect they just need a bit of a refresh and checking connections to ensure reliable operation.
    If you can PM me contact details I will send one of them to you for inspection/refresh.
    Cheers, Paul.
    Mar 2009
    Bexley NSW 2207
    hi paul
    the most secure way is to send it to T.R. Spares Pty.Ltd 45 Fairford rd Padstow NSW 2211, as they handle all my valve blocks and BeCMs.
    otherwise call me directly on 0421 509 083 and i can give you my details.
    regards Rupert
