Results 1 to 8 of 8
Thread: Falcon Engine Conversion
    Jul 2007
    Townsville
    Good morning
    I want to fit a 250 cross flow Falcon engine to my 1981 109 hardtop. I don't want an inline Holden or a V6 Buick as for me it is Falcon or nothing.
    So can anyone point me in the direction of a conversion kit and further info on what is required for said conversion.
    Feb 2010
    What gearbox? you can mate a top loader, C4 auto or np435 gearbox to the series transfer case and you'll be sweet. If there's any kit around that uses the series gearbox, dont bother .
    Invermay Tasmania
    It would be easyer to install a rover V8
    Adam
    Mar 2009
    Collie W.A.
    Quote Originally Posted by Disco Stew View Post
    Good morning
    I've heard on several occasions that the 250 crossflow suffers from overheating problems in a Series conversion. Mind you that has always been word of mouth, no direct evidence.
    Jun 2008
    Perth/West Africa
    I have a C4 to series transfer box adapter plate, its all bolted up together at the mo.....
    ...not sure what else you would need.
    PM if you are interested
    Mar 2009
    Royalla NSW
    Falcon engine
    I converted a series 2 SW many years ago to a normal 250 eng. Had so much power it was not funny. I once towed a full size buick on my trailer at over 80 mph with it! On Land Rover brakes - the things you do when you are young!!
    But it can and will break things:
    Rear axles (rover rear diff) - fixed by a 9" diff centre and axles!
    Gearbox - replaced by a marks 5 speed caball gearbox conversion (anyone got one laying around?)!
    Front diff - centre replaced by a BW 8" (ratios changed to 3.89:1 to match up)!
    Overheating - used a hulix radiator which kept it cool most of the time. A desert cool custom radiator would probably eliminate this issue.
    Great fun, but you will need a lightright foot with std running gear.
    Regards.
    Jan 2008
    Goodna QLD
    Have a look in projects and tutorials. Wozapinin has done the conversion and I am starting the process. Tis a big job.
    Jul 2007
    Townsville
    Thanks to all
    I do understand it will be a big job but it is what I want. I have two passions as far as motor vehicles go and that is the Ford Falcon and the Land Rover. I have previously had a Disco 1 (V8 auto) but am enjoying the idea of combining both my loves into one vehicle.
    I have an XE donor car which is a 250 auto so I suppose the next thing is to check what gear box it has though I expect most likely the BW 35. As for cooling I will be upgrading as necessary etc.
    Thanks again and looking forward to more hints and tips.
    Mark
