Will depend on who has been doing the services?Whether the services have been done fully.Some people replace oil and filters,and call that a service!!!
If it has been maintained by someone that understands 4wds and especially Landrovers,then all should just be normal,nothing special.I am always amused when magical mileage numbers pop up.Where things are supposed to happen.There are too many variables,and if you begin worrying about what could go wrong with a Landrover,you will end up with an ulcer
Things to make sure that have been done though,include Timing belt and pulleys,as these are a service by Km item.Never hurts to have valve clearances checked,as a slightly tight valve will not only rob the vehicle of power,but can cause a burnt valve.Wheel bearing adjustment and check the unis for any play.People tend to just pump them full of grease and not check for play,and then wonder why they fail out on the track.
The rest is just regular maintenance.
Wayne
