Results 1 to 10 of 21
Thread: Zenith Carb, new. (any good?)
    ashhhhh Guest
    Hey all
    Has anyone purchased a new Zenith Carb?
    Ive heard some of the new ones are poorly made.
    Im looking at getting one from CLR - Land Rover Series 3 Zenith Carby - Brand New - eBay Engine Parts, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 01-Jul-10 06:47:36 AEST)
    The price is reasonable I reckon.
    Ash
    I have heard that some of the new ones are more prone to having the top warp, but I have yet to hear of a specific person who has had this happen.
    That price is about what you would expect to pay for one.
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    It might be worth your while to look at ERC2886 CARBURETTOR ZENITH TYPE | shop | www.lrseries.com | L. R. Series, which works out to $A105 plus shipping.
    The Zenith 36IV is also available from other overseas sellers, but these are the cheapest, and the carbs all seem to be the Indian made models.
    There's nothing kicking around on ebay other than Gary's offering - I've got a permanent search set up.
    Peter
    ashhhhh Guest
    Yeah right thats a fair bit cheaper!
    Ive gone with Gary's though - it will get here faster and if its rubbish I can go back to him.
    Ill post the results when I get it.
    ashhhhh Guest
    So I got the carb today, fitted this arvo - looks good so far.
    I haven't driven it yet but the idle is much more steady and throttle response is a lot better.
    Just a question about the mixture on these carbs though...
    How do you tell when the mix is set right?
    The manual basically says "turn until best idle speed"
    What I always find is that there is a massive range (many turns) between the poor running "in" and poor running "out" positions...
    Any advice?
    Quote Originally Posted by ashhhhh View Post
    Any advice?
    If this is the case, the most likely problem is that the idle speed is set too high. This should be 500rpm, about half the idling speed on modern engines. As you get closer to the correct idling mixture, reduce the idling speed to keep it close to that figure. If you have no easy way of determining the actual speed, reduce the idling speed to as low as it will keep running to adjust the mixture, and keep reducing it when it goes up as the mixture gets closer. (If the idling speed is too high, only a small part of the mixture going into the engine comes from the idling system, so of course, changing the mixture on this makes little difference)
    Ensure that the throttle linkage is not limiting the idle speed, in particular the spring on the bell crank should push the linkage against the idle stop.
    Bentleigh 3204
    Zenith Carby
    Bought Carby from the above link in U.K.
    Arrived yesterday ........genuine Britpart
    Fitted today and engine now Purrs
    ashhhhh Guest
    Just wondering, which way do you go on the mix screw to make it richer?
    In or out?
    In or out?
    In, from memory - it adjusts an air bleed.
    ashhhhh Guest
    OK thanks.
    I may still be having some rich running issues with the new carb....im still confused by the idle adjustment..
    If wound in too far it stalls quite quickly but when wound out it seems to be 4 or 5 full turns before anything happens....
    Im used to having a narrower band (motorbikes) so such number of turns make me think something is not right.
    Idle speed it as low as it can be so im sure it is slow enough to be accurate with the mix.
