Biggest problem with the V8 County will be that the last one was made over twenty years ago!
I would be inclined to get one without factory air. In most cases the "works" will need considerable work, which will be both labor intensive and need a lot of parts that are not very easy to find. And it is not very good even when it is working.
The five speed box is probably better from the driving point of view, but the four speed is more durable, not that this should be a problem with the V8.
Look for one that is as original as possible, and has not been used as a bush basher.
The doors changed from lift up to push button handles in 1987. The earlier ones give you more elbow room, but the push button ones rattle less and are probably more durable. Both have frames that rust quite well. Check rear door for frame broken by weight of spare, especially if oversize wheels have been used.
For preference avoid ones that have had the electrics messed with, and make sure everything works.
Check all suspension bushes and the ball joint on top of the rear axle, but expect to replace some bushes anyway. Check whether the self levelling strut (if still fitted) works - it probably doesn't. Look for leaking steering box, tie rod ends with free play, swivels needing attention, bent tie rod (or heavy duty one installed). All of these can be fixed readily but affect price.
Rust is most likely to be in the firewall, rear crossmember, door frames, centre door pillar. Seat box is largely steel, check for rust, although this is probably the cheapest part to repair. If possible get one that is from the inland, and avoid ones from the tropical coastal areas.
Check condition of seats, upholstery, foams and steelwork. Check dash area for disintegrating bits of plastic - these are mostly available, but do add up.
