Results 1 to 10 of 11
Thread: One for Inc
    One for Inc
    Mate ... Just happened this morning.
    When I click on various threads, up pops an Adobe Flash Player 10 message ....... A script in this movie is causing Adobe Flash Player 10 to run slowly. If it continues to run, your computer may become unresponsive. Do you want to abort the script? Y/N
    Happened twice. Any suggestions ?? If I select Yes, all is OK. If I select No I get the old "Not Responding" message.
    d@rk51d3 Guest
    Had the same issue this morning. Thought it must have been a dodgy ad.
    Sent from my jailbroken iPhone using Tapatalk
    miky Guest
    Working OK - as normal for me using Firefox.
    Just checked IE and still OK.
    W7 Prof. machine.
    Hay Point
    Quote Originally Posted by Rosco View Post
    Happened to me too when I viewed the ww2 submarine photos. Managed to stop it happening by logging out and resigning back in.
    Cheers......Brian
    1985 110 V8 County
    Nov 2008
    Mostly over there
    22.04 MB
    Yep, me too!. Just in the process of checking why. glad to see others had the same issues... this site seems to stop responding until i click the "Yes" button to disable the script. A few minutes later the same message box appears again.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    not seen it myself so cant positively comment on why this time around but i have seen similar issues on machines with flash and internet exploder.
    running a util like atf-cleaner can often help
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Avoca Beach
    site running slowly- error message
    I am experiencing a new thing on the site in the last few days.
    I have add ons disabled on my IE .
    However , first the pages load quite slowly and I am now getting an error message " a script is causing Adobe Acrobat to run slowly. Do you want to disable the script"
    If I say yes. A drop down ad comes up then goes away.
    Now I am all for the site making money and I am not currently a subscriber but please administartor could you follow the same protocols that just about every other site with drop down ads follows.ie there is an"X" in the corner which allows them to be bypassed, and not force them especially since there seems to be a programming glitch that is slowing down the site
    Regards Philip A
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    adobe flash maybe, cant see acrobat being the problem...
    but then again it is probably another elitist plot to deprive you of something.
    there are plenty of posts on here that tell you how to get around it.
    FYI, the adverts are the same ones served out by the advertising agencies to all their clients. their servers dish them out. nothing special employed here that i am aware of but i will pass on your concerns to them and see what reaction i get.
    do you know which particular advert is triggering it?
    i cant get it to occur on my system at all and i am running all the major browsers at once with nary a problem.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    someone has sent me a screen capture of the error and it is a adobe flash plugin itself error.
    have sent it off to the ad agency to investigate
    i still cant induce it on my systems so it is some sort of software issue and more than likely with the lastest version of the flash plugin itself i suspect.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    from the ad agency
    Looks like it was a temporary glitch, at Google’s end, and seems to have resolved itself. However if it happens again, let me know and I’ll definitely look into it.
