Results 1 to 10 of 13
Thread: Passenger side hot air only.
    Oct 2007
    Williamstown, Victoria
    Hi all, I thought I'd give the A/C a run today in my 2001 HSE 4.6 RR and noticed cool air only coming out of the drivers side and hot air coming out the passenger side.
    I've read a bit about the hevac motors playing up and causing similar issues.
    The cheque book symbol has been coming on since I've had the vehicle (6 months), have not had the codes read for that as yet.
    It seemed to be working fine before that.
    Any advice on where to start looking here?
    Mar 2009
    Bexley NSW 2207
    its most probably the blend motors, but the Hevac can cause the same fault.
    get the codes read and cleared, check the live readings and try swapping hevacs.
    this may even get a stuck blend motor going again.
    May 2008
    Peter - if you are near Canberra, drop around and see me. I have a multi-vehicle licence on my FaultMate for the HVAC which will read and clear your fault.
    Cheers, Paul.
    Equally, if you are near Penrith, I have a Testbook that can do it, too.
    Oct 2007
    Thanks so much for the very generous offers PaulP38a and p38arover, I would definately take you up on that, only I live in Williamstown, west of Melbourne.
    I was planning on aquiring a faultmate for myself anyway, maybe it will now happen sooner than later!
    Cheers, Pete.
    Ahh.
    Update your profile to show your location (at least the general area).
    May 2008
    Quote Originally Posted by PeterH View Post
    Cheers, Pete.
    I can help you with that too
    Oct 2007
    Thanks for the offer Paul, have pm'd you.
    By the way mine is a 2001 4.6 HSE.
    Cheers, Pete.
    Jan 2008
    Medowie, Port Stephens and Sydney
    Looking at the thread title, I thought you might be talking about my missus
    WasabiPimpNinja Guest
    Quote Originally Posted by LavisLane View Post
    Hahaha... Well played Good Sir... Well played...
    Keels
