Results 1 to 10 of 17
Thread: Need a new (replacement) jack suit a Defender 130
    VladTepes's Avatar
    Bracken Ridge, Qld
    The one thats in the Defender is... to put it mildy.. rubbish. It's a black bottle jack type of things which you have to wind up and down. Bloody slow and tedious I can tell you. Plus the handle bits seem to be bent, or at least bent wrongly.
    My trolley jack is WAY to heavy and bulky to carry about !!
    Anyway what have people found that is best (for wheel changing not recovery).
    I'd appreciate all input / experience.
    And yes i have read this thread:
    need a jack for my county
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    the red rover jack as fitted to discos.
    Oct 2006
    Boisdale, Victoria
    I bought a 7 ton Masada jack made in Japan from supercrap for $120 which was cheaper than the bidding war on $bay for a 2 ton disco jack
    Attached Files Attached Files
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    I have a bottle jack with the Puma D130 ute, and used it a lot recently with a pile of besser blocks and planks to remove the tray.
    It worked ok, but was prone to bleed down fairly quickly.
    I have an old Lightburn hydraulic jack in the truck that will eventually go in the D130 as a backup.
    Feb 2005
    i measured the gap between the ground and diff/jacking point with a flat tyre, went to the wreckers and brought a bottle jack that was a little bit smaller.
    it need a top up with oil its been going good for four or so years
    one rock lobster ($20) from memory
    VladTepes's Avatar
    Bracken Ridge, Qld
    Quote Originally Posted by Dave110 View Post
    Going well is it ?
    How does the height compare to the standard Disco bottle jack ?
    Anyone know what a standard disco bottle jack can be had for $ wise ?
    gone
    1996 Discovery 1
    current
    I carry a Land Rover jacking point adaptor for the high lift. The problem with that and the original Defender jack is that you jack the body up so much before you get a wheel off the ground, that the jack becomes unstable.
    I also carry a hydraulic jack. The RR Classic / D1 jacks are best as they have a yoke that locates well on the axle housing. So if we're going on a family trip, I take the jack out of the RRC.
    I think that I would really like to get an air/hydraulic jack, so I can just slide it under the axle and turn the air compressor on. I think it would be faster, safer, easier to adjust and mean I wouldn't get as dirty crouched on the ground manually jacking it up. Friends and I are toying with the idea of making a jack from a (suspension) airbag, which would do the same thing, but be a lot lighter.
    Quote Originally Posted by VladTepes View Post
    ...Anyone know what a standard disco bottle jack can be had for $ wise ?
    they're going for about $50 on ebay
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    any one lashed out on one of these?
    They aren't cheap either.
    8<----------------------
    Air Jack
    AU-JACK1
    Working pressure 100 psi.
    Lift capacity 2500 kilos (2.5 ton)
    Minimum height 160 mm.
    Maximum height 465 mm.
    Total weight 13.5 kg.
    For more information click here.
    Retail
    AU$750.00
    GST Inclusive
    8<-----------------------------
    VladTepes's Avatar
    Bracken Ridge, Qld
    If you look at the pdf attached to Dave's post earlier up the oage you can see that mob do a pneumatic / hydraulic jack which can be operated manyally as well, in the event air is not available.
    It's not clear whether the air has to be at very high pressures but I wouldn't think so.
    gone
    1996 Discovery 1
    current
