Results 1 to 10 of 24
Thread: New MODERN Series owner
    Williams West Aust
    Hi Guys
    Just joined your club.
    1999 TD5 Extreme,148000ks,in very good nick.Bought for next to nothing!!!!
    Already got my head around the TD5 bit,being a D2 TD5 pilot.
    Just drove the new Defer home tonite,got a few questions.
    Heater,dosnt produce any hot air.The hot cold slide doesnt seem to be engaging anything.Havent looked under the bonnet as its dark,any common faults here????
    The switch at the LHS on the instruments,has a fan icon and 2 on it,what does it do,doesnt want to move,havent tried any force.
    What happened to the Series floorboard heating system????? could have used it tonite!!!!!!
    ABS light stays on for 5 mins and goes.I cant Nanocom just yet as I never entered the Defender unlock codes into mine,just need to find them and do so.It has a turbo timer and electric brake controler,do these cause this???
    Seems to be a warning beeper when first starting????Like a muffled reverse beeper?????goes for 30 seconds or so.
    This runs HEAPS cooler than my D2 TD5.80deg most of the time,84 was the higest I saw.Perhaps it was a good move buying that new radiator for the D2,its still sitting in its box!!!
    Im sure I will have LOTS more questions.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Nov 2008
    Gone
    Hope I can help. The fan only seems to operate when the two temp. heater controls are set for heat. The fan only operates on setting two, the other settings are to adjust airflow from the intake, as if. I only found this out when the dealer had to replace the fan moter in our 90, cost them about $800 all up for the job as the air con unit ect has to be removed. I hope yours is just cable adjustment. Ours seems to run cooler than the Puma but in summer I think this could be a plus. Good luck with your new vehicle.
    Allan
    NSW far north coast
    Hmm, my Tdi has two fan speeds, as Alan said the first portion just progressively opens the flap in the ventilation box, the last two stops are the fan. Oh, and the fan should work regardless of where the heater is set.
    As for the heater, when you look under the bonnet you will see two control cables going to the heater box, the heater one opens a flap that lets the air flow through the heater core, water goes through all the time.
    The cable can jam inside the outer, it can pull through the clamp on the lever at the heater box.
    None of my controls worked when I bought the beast with less than three years of use.
    I had to strip everything and used copious amounts of bike chain lube down the cable (Rock-n-roll, it's a dry lube, that the carrier solvent evaporates after a little while) and I've never had a problem in the last near eight years.
    Also check that the seal at the bottom of the core is sealing the core to the box. This can fail and let under bonnet air in all the time.
    Bloody uncomfortable in summer dragging all that hot underbonnet air in.
    Nov 2008
    Gone
    Quote Originally Posted by rick130 View Post
    My old 300 TDI also had 2 speeds, don't know why they changed the TD5 as they both have same control levers
    Allan
    Williams West Aust
    Book of words tells me the ABS light stays on until 8kmh.
    The fan lever on the left doesnt seem to move at all,like its siezed???? How far should it travel???
    Andrew
    Invermay Tasmania
    It should move Andy on my old 130 it was very stiff until I pulled it apart and gave a clean
    Never had the abs light at all and i say to check the heater box to see if it changes between hot and cold
    Adam
    Williams West Aust
    Thanks Adam
    130's didnt have ABS/TC did they????
    Will get some checkerplate off you in the future
    Will add some pics in a minute.
    Andrew
    ### EDIT,cant get into my photobucket account,will try again later###
    Andrew
    Nov 2008
    Gone
    Andrew
    About the same distance as the other two levers. their is a click felt when it switches the fan on at the bottom of the slide.
    Allan
    Jul 2003
    Welcome to the Defender madhouse Andrew
    Mahn England
    Ex 300Tdi Disco:
    Williams West Aust
    I got that heater lever to move,just wasnt trying hard enough!!!!
    Still cant get into my Photobucket A/C.
    We have gone over our monthly broadband limit,so it could be part of the issue.
    I managed to get some pics on LandyTown before the slow down.
    See pics here.
    LandyTown :: Log in
    Andrew
