Results 1 to 8 of 8
Thread: Tailgate won't open. Any ideas?
    Jan 2010
    Newcastle NSW
    Hi All, tailgate won't open, any common faults/fixes??
    Jan 2010
    Newcastle NSW
    Meant the bottom half, top half does. I can hear the solenoid(s).
    Jan 2008
    Medowie, Port Stephens and Sydney
    Mine sticks occasionally and i need to give it a nudge. Guessing you've already tried that?
    May 2010
    Northern Beaches, Sydney
    If you can hear the solenoids going then it is probably a broken cable that connects the solenoid to the catch mechanism. Had that happen on my D3. Easy DIY fix once you get pass the difficult access problem to get the door to open.
    May 2008
    if you can't hear/feel the solenoid trying to work, it is most likely a broken wire or contact. You can force the inner lower tailgate cover off but you may break it and the surrounding trim in the process. At least then you will be able to access the back of the button and remove it for closer inspection.
    I have a "spare" button here if you want to borrow it... you have my number.
    Paul.
    Jan 2010
    Newcastle NSW
    Flat battery... enough to move the solenoid, but not enough to move it enough to open. All good.
    Brisbane, Inner East.
    Nobel AB gelatine dynamite. Use a very small charge.
    URSUSMAJOR
    Bracken Ridge, Qld
    brian is on the right track but start small...
    sledge hammer
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
