Results 1 to 10 of 14
Thread: Electronic speedo to LT95
    Geelong, VIC
    I've got an electronic TD5 Defender speedo that I'm considering fitting to my county (LT95 box).
    There are a number of articles on the web about fitting them to early defenders in place of the mechanical speedo, but they are all LT230's and I cant find anything on fitting to the LT95.
    Wiring isn't a problem, its just whether the electronic transducer from the LT230 will physically fit the LT95 speedo drive mount.
    Anyone already done this or can say for sure whether or not the transducer fits?
    Steve
    Invermay Tasmania
    When I looked into this I was told that the LT230 transducer is screw in and the cable on the lt95 has a clip holding it in.
    The other way is to go the magnet on the tail shaft or try and do a conversion (I was going to do this but Im running out of time)
    Adam
    Bracken Ridge, Qld
    I ahve a 300Tdi (andtherefore i suppose the LT230) so can you supply the links for the conversion you mention please ?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Avoca Beach
    I would think someone like Flexdrive industries could make up a composite cable to fit.
    A RRC 89 on has a short cable with the transducer on the LH chassis rail. maybe get one and have flexdrive graft on the LT95 end .
    Regards Philip A
    stefan_bonnici Guest
    Quote Originally Posted by VladTepes View Post
    Sorry to bump in ! i am gathering all the supplies at the moment to do this.
    I now need a td5 speedo with km/h cause the one i have is in miles (big numbers and km small numbers) and dont know if the odometer will be in miles of km
    If anyone has a speedo for me let me know ! thanks
    Links to the conversion is here
    Installing a Defender Td5 Instrument Pack into a 200Tdi/300Tdi - Land Rover Technical Blog
    Upgrading a 200Tdi Defender to Td5 dashboard warning lights | Land Rover Expedition
    Very Helpfull !
    Darwin
    The disco Tranducer of a D1 will plug into the LT-230 & LT95. When I went from the 95 to the 230 I didn't have to change a thing.
    I've also fitted a VDO digital speedo and got a transducer from New England Instruments made up.
    Geelong, VIC
    Regards Philip A
    I guess there's always that option, but rather hoping I can go all-electronic and not have a flex cable at all.
    Steve
    Geelong, VIC
    Quote Originally Posted by Larns View Post
    Thanks Larns - sounds positive.
    Steve
    Geelong, VIC
    Quote Originally Posted by stefan_bonnici View Post
    Very Helpfull !
    And in case the P/N's aren't in those links, here they are:
    speedo(km/h): YBC101530 ==> I have one in front of me and its definitely kmh
    transducer: YBE100530 ==> haven't physically confirmed myself - info from one of the UK forums.
    Steve
    Mar 2007
    Canada
    Just to update this for everyone... YBE100530 fits the LT95 with no issues.
