Results 1 to 10 of 15
Thread: Air hose and fittings
    Bracken Ridge, Qld
    The air hose on my compressor **** itself, so I need a new one.
    The one I had was similar to this:
    Though yellow and relatively thin walled.
    I suspect that for something more hard-wearing I need this kind:
    As far as the fitting which connects the hose to the tyre valve for infaltion, I want the type that has a little catch you depress by thumb, push over valve, release thumb and it then stays in place. Like this:
    or this heavy duty looking one:
    I am not sure what they are called but haven't seen any in the el cheapo shops at least.
    So what i need to know is:
    Where should I go to buy this sort of gear (super cheap were useless),
    How many metres of tube should I get ? (I have a Defender)
    Also does anyone know if there are ANY reliable in-line pressure guages for tyre inflation. The one I had read up to 10psi out. I;d love to be able to watch it rise to the desired pressure then just pull the hose off the valve - done! Possible or not ?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Crafers West South Australia
    Google "tyre chuck", I found lots.
    Kallangur, Brisbane
    Try these guys maybe Compressor Care (Strathpine,QLD)
    + 2016 D4 TDV6
    Aug 2008
    I've always gone to industrial air fittings suppliers for decent air products over here in the West.
    A quick search brings up this place that may be ok (not sure how far it is really from you?): We Carry Pneumatic Parts, Pneumatic Machinery, and Airline Installations for All Your Pneumatic Requirements
    Brisbane, Inner East.
    Try Tony Powell Hose and Fittings at Geebung.
    URSUSMAJOR
    Bracken Ridge, Qld
    At least i;ve found it's called (I think) a "clip on sealing chuck"
    gone
    1996 Discovery 1
    current
    Bracken Ridge, Qld
    Quote Originally Posted by Brian Hjelm View Post
    Tony Powell Hose and Fittings Pty Ltd - Home
    They good to deal with Brian as in if I went in there not knowing my arse from my elbow (technically speaking) they'd be able to sort me out the bits I'd need. (for this an for later plmbing in air tanks etc).
    gone
    1996 Discovery 1
    current
    Bacchus Marsh Vic.
    Something I did before buying my fittings was have a look at the service centre hoses near where I play.
    No need to go inside and get the abused gauge when my fittings clip straight in
    The guy behind me usualy thinks I've stolen the gauge as I leave though
    I have my clip on chuck on a short(100mm) hose with a male connector(also deflates tyre if needed).
    Hose length is best worked out from the compresor to your futherst tyre.
    My compresor is under my L/H seat so the hose reaches all my tyres and a car parked close to the L/H side of me if needed.
    I have a spare hose in the shed so I could extend the hose if I get a trailer(saves unhooking).
    If you think about your conections you could clip it to the spare for a short burst of air if needed(air filter/Dust from any thing).
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Feb 2005
    Quote Originally Posted by VladTepes View Post
    we deal through these guys at work, always very helpful
    these guys are really helpful Pneumatic Products - Metalwork, Clippard, Legris, Donaldson, Camozzi they are at brendale, i brought my hose and fitting off them a few years ago and recently dropped for some imperial (why why why) hose fittings for my lockers
    WA
    Another option is QLD trade tools - that's where I bought all my bits when in QLD - including a tyre chuck like you want.
