Results 1 to 6 of 6
Thread: A pretty accurate dyno and 0-100 device for $13
    Nov 2008
    Found an application for the Iphone/Ipod that uses the inbuilt G meter and data from the user on vehicle weight to calculate power, braking, 0-100 and quarter mile data. Its remarkably accurate. Could be good for tuning. Check out the video below:
    [nomedia="http://www.youtube.com/watch?v=0-DFbJQbeSY"]YouTube- iPhone Dynolicious Software Better than G-Tech? -Garage419[/nomedia]
    Ferntree Gully, Vic
    Might be an interesting app to have.And not overly expensive as well.
    Nov 2008
    Quote Originally Posted by SPROVER View Post
    I tested it on the wife's Ford territory. Ford quotes the model as having 172kW(that would be on premium ULP). I got 152kW on the test on standard ULP. I factored in 20% loss through drive train but it could be a bit lower loss. You can run it so it keeps rear wheel hp. Car is due for a new air cleaner and plugs.
    Kiwiland
    I ran it on my work car the other week (borrowed ipod touch). Max 38kw, but the power graphs levelled out at about 20kw.
    I thought it was getting slower, but I didn't think it was that slow. Time for some filters I think.
    Bracken Ridge, Qld
    Yeah an iphone app will do what a dyno costing 10s of thousands of $ is normally required to do.
    Rubbish.
    Even a dyno that doesn;t have an inlet air temperature sensor being used is useless.. and you see that all the time.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Kiwiland
    Quote Originally Posted by VladTepes View Post
    Rubbish.
    I hate to break it to you, but a stopwatch, known distance and some maths can tell you the basics that most employ expensive dynos for.
    I just replaced the fuel filter on my work car and it's now reading 50% more power than last week. Still down on factory specs but wow, best $20 ever spent.
