I have repinned my drivers door hinges. I suggest that you consider drilling a little undersize and ream to size, leaving part of the hole unreamed in the post part to secure the pin.
The problem with your wipers will be a fault with the parking circuit. This may be either in the park switch in the wiper motor, which is as noted, in front of the LH passenger's knees, and not exactly easy to get at , or in the wiper switch, which, if it is arranged the same as in earlier Landrovers, supplies voltage for the park circuit when in the off position. Less likely is a loose connection.
