Results 1 to 10 of 11
Thread: Yes oils again... but cant find answers?
    Oct 2006
    kinross, Perth, WA
    Hi Guys
    Just looking for general input.. defender 2002 extreme
    Service is due... tomorrow.. ! i have ordered some syntrans 75/85 for the gearbox as its notchy when cold.. but have tried to find recomendations for the transfer and diffs... no joy..
    Its rover diffs front and rear and i'm assuming an lt230 transfer
    I could do with capacity too if you dont mind.
    Edit forgot to say its used for towing quite a bit too..
    Thanks in advance
    Steve
    I run Penrite Hypoid 80-90 in the diffs and transfer.
    HYPOID 80W-90 - Penrite Oil
    Transfer case from memory is about 2.7 litres
    Diffs are less. a bit under 2 litres each I think.
    Here's a good start -
    http://www.aulro.com/afvb/good-oil/7...g-rick130.html
    TC is 2.3 litres
    Diffs are 1.7 litres each, unless oil fed wheel bearings, then more like 5 litres for diff and bearings and, maybe 3 litres for rear.
    Oct 2006
    kinross, Perth, WA
    Quote Originally Posted by Psimpson7 View Post
    Thanks Pete.. am i assuming your running a salisbury diff? as the 2002 defenders run a rover... which isnt hypoid? or does that not matter
    Quote Originally Posted by abaddonxi View Post
    TC is 2.3 litres
    Thanks.. i dont know if that helped or confused me more.. lots of info.. just need to try and sort it out..
    The penrite i like the idea of as i run that in the engine and boat.. its a bugger to find tho...
    Thanks for your help guys
    Steve
    Hi Steve, No I run a Rover type. The Penrite link specifies its fine in spiral bevel diffs too.
    The other threads linked, and the ones in the 'good oil' section while having some really good info are a bloody nightmare to navigate.
    Someone needs to do a table with the different engine/egarboxes/transfer cases etc which we can post up as sticky. it would make life a lot easier.... in fact I may do that.
    I run mobil Delvac1 synthetics for both engine and driveline as we have it off the pump in the workshop for all the late model Actros trucks.
    Jul 2009
    Lake Macquarie NSW
    Fella's.
    In my '04 Td5 Disco, I run Castrol Edge 5w30 in the engine, Caltex MTF94 in R380, Castrol syntrax 75W90 in transfer and at the moment, LSD compatable (although I dont have LSD) Castrol EP Gear oil to OEM specs. Next change I will run Syntrax 75w90 in diffs. MTF 94 is no longer availabe, so when I run out I will run Syntrans 75W85. Do yourself a favour and get a rave cd, all info at your fingertips.
    Regards Robbo.
    NE Victoria
    32.83 MB
    Quote Originally Posted by LOVEMYRANGIE View Post
    Hi,
    Isn't Delvac1 an engine oil?
    Do you run it in the whole drive line?
    Tony
    NSW far north coast
    Quote Originally Posted by TonyC View Post
    Hi,
    Tony
    The Delvac name covers Mobil's HD oil range, eg Delvac 1 ESP 5W-40 engine oil, Delvac synthetic 75W-90 GL5 gear/diff fluid (the old SHC 75W-90), Delvac MX 15W-40 engine oil, Delvac 1330 15W-40 engine oil, etc
    This is easier, here's a link
    Mobil Oil and Greases Distributor - East Coast Lubes - Delvac Range
    NE Victoria
    32.83 MB
    Quote Originally Posted by rick130 View Post
    Once again, thanks Rick!
    Tony
