Mick
Do it yourself, those boxes are quite easy if you follow the OEM manual. Just remember that a number of the gears are in pairs*, so have to be replaced as such.
A lot of parts are mix and matchable with the parts from later boxes.
What you probably will find is that you have the wide 3rd gear set, which requires the bronze bush with the narrow shoulder, otherwise you have to change to the late wider type that has the narrow 3rd gear pair.
The things you need to be aware of are the needle roller bearing at the front of the mainshaft; the locator pegs on the 2nd/3rd bronze bush, the bush broken, the end float on the same bush; a broken layshaft circlip; wear in any part of the 3rd/4th synchro mechanism.
Your pre-removal symptoms should give you an idea.
Always replace the layshaft bearing. Check the reverse idler bushes.
Diana
* Primary pinion and layshaft constant gear
3rd gear set
2nd gear set
ADDIT: Woops - I read that you were doing a 1951 gearbox not a 51 year old - sorry. forget the stuff about narrow bush. If it's not already a Suffix D or Suffix G/H box (the same really) you should retrofit it to suffix D. They are the boxes with the large layshaft front bearing and the shoulder retaining 2nd layshaft gear. All the rest is the same.
