Results 1 to 6 of 6
Thread: Sagging new front spring
    Scarborough, QLD
    I've recently installed new 130 springs (and shocks) in the front of the 110 wagon. For some reason the drivers-side spring is sagging about 1-2". I'm pretty sure I used the longer spring on the right.
    Before I pull both springs out and double-check, is there anything else that might be causing this?
    Perth W.A.
    damn shame what a pain in the suspension would you expect any settlement ?
    I don't know just asking ..got any shots of it as it is ?
    good luck old bean
    Dayboro, Qld
    Just a thought, is the left spring seated correctly ??
    I've just fitted new king springs and terra firma shocks to the front of my county and had a few dramas. Looking at the pics you can see new spring against old,but when fitted vehicle was 20mm lower Turns out I was given wrong springs.Other pic shows correct spring against wrong spring.I also had lots of dramas with the new shock bushes but now have it all sorted and the vehicle drives great I didn't realise how stuffed the old ones were !!
    Before spring replacement it measured 900mm from floor to wheelarch, with wrong springs it was 880mm and soggy, but with correct springs (allowing for a winch and winch bar not yet fitted) it now measures 925mm.
    Hopefully replacing the rear end this weekend, one thing I have noticed now is that the headlamps need adjusting as they shine up in the air a bit
    Kingston, Tassie, OZ.
    Quote Originally Posted by Ranga View Post
    Blue/red spring is drivers side. (NRC9448) it is 3/4" taller free length. Also, if one of the rear springs has dropped, it'll affect the front somewhat.
    JC
    Oct 2006
    The Vines WA
    Does the spring have any reference info stamped or painted on it to save you removing it to check?
    When I had my crisis of confidence whether I put my King springs on the correct sides I could confirm by looking at the code.
    Chris
    Normanhurst, NSW
    Quote Originally Posted by LoveMyV8County View Post
    Chris
    NRC9448 (Drivers side) is colour coded blue/red and has free length of 388.6mm. NRC9449 (Passenger side) is colour coded yellow/white and has free length of 376mm.
    Roger
