Results 1 to 10 of 19
Thread: loss of power in 5th gear
    gold coast
    I hav a 300 Tdi and have been loosing power in 5th gear, I have been driving on the M1 to work each day and she powers up to 95-100kmh in 4th ok but when i go into 5th gear its all good on the flat until i start up a small incline. I will be doing 110kmh then she just won't hold it on any incline and the steeper the hill the slower she goes.
    I will need to do an oil/filter change in 1000k but everything else looks ok in the engine bay.
    there is a slight leak out of the rocker cover and the oil rubber tube that goes from the head cover to the block. (6 inch long pipe with an elbow at the top)
    Any ideas would be appreciated.
    Safety Bay
    What size tyres do you run?. Pat
    Go and get some diesel addative and put that in. There is a slight problem with the 200 and 300 tdi and that is that these days diesel has a low amount of sulphur in it and the injector pump needs it to work to work at it's best. So putting addative in to the fuel puts that back in and then gives you back the mid range torque which is what you are missing. Makes road driving and hill driving alot better
    Sent from my iPhone using Tapatalk
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Mar 2010
    Mudgee-ish
    1st - check for water/gunk in the fuel (valve at bottom of fuel filter). Will it rev out in lower gears? If not - injectors and or fuel pump.
    Hunter Valley
    Check the hose on the top of injector pump that goes to the turbo. They can melt or split, but the loose power in every gear. still needs to be checked.
    gold coast
    high revs in each gear sounds like its pounding its own exhaust. I will look at the hoses.
    gold coast
    Quote Originally Posted by PAT303 View Post
    its only been in the last week, but i have 235/85/16 MAXXIS on at the moment.
    gold coast
    Quote Originally Posted by Reads90 View Post
    I did add a liquimoly Diesel anti nock Plus to the last tank of diesel i bought, maybe it loosened some dirt etc as it went thru the fuel line.
    Mar 2010
    Mudgee-ish
    Quote Originally Posted by philco View Post
    They are the same rolling radius as the standard 7.50 x 16, so they are not the problem.
    Williams West Aust
    Check the throttle cable adjustment.
    Its a common issue on the TDi.You may not be getting full travel.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
