Results 1 to 4 of 4
Thread: Washer supplier?
    Jul 2009
    Forest Hill / Kyneton
    Washer supplier?
    I'm going to replace the oil in my gear box and transfer box. The book says I should replace the washers on the drain plugs.
    Where do I get the washers? Repco, Bursons, Land Rover parts supplier?
    Bacchus Marsh Vic.
    Any of them but for Repco ect. you proberly need the plug
    I've found that unless they are really damaged you don't need to change the washer.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Jul 2010
    I've found that most of the bearing and seal suppliers sell "grab-it" kits for multiple application and sizes eg -
    Washers - steel, copper, alloy, d-clips, circlips, o-rings, split pins, nuts, bolts, nylocks the list goes on and on!
    They are made by 'Champion' and are named 'Champion Assortments' and come in orange boxes and offer you a wide selection within the 1 kit. You'll will find them essential when working on your equipment and wonder how you managed without them....cheap too!
    Ipswich QLD.
    I think for gearbox and transfercase plugs, you will probably need to go to a supplier of Land Rover parts, Repco and others don't normaly stock copper washers that big.
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
