Results 1 to 10 of 16
Thread: Re-chipping a Tdi Defender
    Bracken Ridge, Qld
    I searched high and low on the net but could only find stuff relating to the TD5's.
    Therefore I have done this tutorial to show others how to re-chip their Tdi Defenders (should also work for Discos) to take advantage of the latest technological advancements.
    The photos are all taken from the RHS of the vehicle (cab is to the left of frame) - so that you are oriented.
    Photo 1: Location of old chip.
    Photo 2: Removing old chip is relatively easy.
    Photo 3: Comparison of old chip and new "microchip".
    Photo 4: The new "microchip" in place and ready to go.
    Photo 5: The manufacturer has allowed for variations in dimensions in Land Rover Defenders (no two are the same) by supplying a number of various sizes of chips in the pack.
    I'll do a road test later.
    Photos:
    Edit:
    Road test result: Chip fell off. Back to the drawing board.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Queensland, Ipswich
    thanks for the heads up.
    I'll gentle tap mine into place with a hammer......ooops!!!!!!
    Jun 2008
    Manning WA
    Someone with a little too much time on there hands .
    Jun 2010
    Perth, Midland
    Do you get even better improvement if you swap from diesel to chip oil?
    2stroke Guest
    Couldn't you just convert the original conventional chip into micro chips? Oh I see that's where the hammer comes in.
    Apr 2007
    NW Tassie
    and I feel you are doing the car a dissevice by using a plain salted chip, I feel a micro chip with a good hint of chillie would be better
    blaze
    Perth, WA
    Hi Vlad, did you practise proper Electro-Static Discharge precautions whilst handling the chip?? Perhaps this could be your problem. Also, you may find using some thermal transfer paste could help your problem with the chip not staying in place.
    Quote Originally Posted by TimNZ View Post
    This is about the best thermal transfer paste you will get!!
    And if it gets messy, wash it down with some homemade solvent!!! Lol
