Results 1 to 10 of 17
Thread: What is the better processor to have
    This
    Intel Core2 Duo 2.4GHz P8600
    or this
    Mobile Intel Core i3-330M Proc (2.13GHz, 1066MHz FSB, 3MB L2 cache)
    I found a 13.3 toshiba I really like but I have found it with both options..
    the one with the Intel duo has 4g ram and 400g hard drive....Comes in at $1199 <<<<<I reckon I could get this down though
    the one with i3 has 2g ddr3 ram expandable up to 8g with 320g hard drive $959.70
    Both come with windows 7 and xp downgrade.
    Thoughts?
    The core2 will have a slower bus speed and at best ddr2 ram. All up slower. The clock speed of the processor isn't as "significant" as before. 2GB of RAM with expansion to 8GB is going to provide more room for growth than a 4GB RAM. But I'd be putting in 4GB anyway. If the 320GB HDD is a faster rpm than the other one it will most likely also have more cache and this with the faster spindle will improve speed too.
    Caboolture.Qld
    ....any processor that has AMD on it will beat the Intel any day.......
    May 2008
    Lismore, NSW
    The i3 processor is a newer design and will be the faster and more efficient unit than the core2 duo. It should also be less hungry on the laptop battery so you should get longer running times. If it was me I'd go for the i3 and boost the RAM to 4Gb. This would be a better system IMHO. My 2c worth anyway.
    Warren
    Currently Landroverless - Still interested
    Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
    richard4u2 Guest
    what is an xp downgrade
    Kootingal
    Quote Originally Posted by richard4u2 View Post
    Most (if not all) systems come with the newer operating system.
    Microsoft offer an XP downgrade for business users mainly that run in an XP environment.
    It just means that your system runs XP instead of the newer operating system
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    from the intel site
    P8600
    Launch Date Q3'08
    Processor Number P8600
    # of Cores 2
    # of Threads 2
    Clock Speed 2.4 GHz
    L2 Cache 3 MB
    Bus/Core Ratio 9.0
    FSB Speed 1066 MHz
    FSB Parity No
    Instruction Set 64-bit
    Lithography 45 nm
    Max TDP 25 W
    VID Voltage Range 1.050V-1.150V
    I3-330M
    Launch Date Q1'10
    Processor Number i3-330M
    # of Cores 2
    # of Threads 4
    Clock Speed 2.13 GHz
    Intel® Smart Cache 3 MB
    Bus/Core Ratio 16
    DMI 2.5 GT/s
    Instruction Set Extensions SSE4.1, SSE4.2
    Lithography 32 nm
    Max TDP 35 W
    Max Memory Size
    (dependent on memory type) 8 GB
    Memory Types DDR3-800/1066
    # of Memory Channels 2
    Max Memory Bandwidth 17.1 GB/s
    Physical Address Extensions 36-bit
    what you going to use it for ?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by RobHay View Post
    Processor AMD Turion™ X2 Ultra Dual-Core Mobile Processor
    Model ZM-86
    OPN Tray TMZM86DAM23GG
    OPN PIB N/A
    Operating Mode 32 Bit Yes
    Operating Mode 64 Bit Yes
    Frequency (MHz) 2400
    System Bus Speed (MHz) 3600
    Wattage 35 W
    L2 Cache Size 2000
    Process Technology 65nm SOI
    Package/Infrastructure Socket S1
    Virtualization Yes
    not quite
    in my experience the older they get the more power they drag, to a much greater extent than the intel cpu's.
    Jul 2009
    Mid North Coast, NSW
    287.34 MB
    this well respected site always has good reviews and charts of all the cpus / hardware etc. against each other:
    Performance Charts Processors - Benchmark
    (toms hardware)
    May 2003
    On The Road
    yep, Tom's Rocks!
    should be your first port of call when looking a new vid cards too,,
