Results 1 to 10 of 18
Thread: 4.6 idle problems.... Ideas?
    Jan 2010
    Newcastle NSW
    Hi All,
    Since i changed my GEMS injectors to bosch GEN III injectors ive developed an idle problem. It also did it when i first got the car and degreased the engine bay, but went away. Now its back to stay.
    When i start it from cold or hot it will idle around 1200 even go to 1800. If i put the car in gear it will settle to 800-850. Take it back out of gear and it will settle around 900. Hot or cold.
    Ive cleaned the idle control valve. I hooked up a basic obd tool and it tells me my throttle position sensor at idle is 17%. When i put my foot on the accelerator and then take it off it goes up and down in percentage. Holds steady if i hold the pedal steady.
    Any ideas??
    Try to get a spare TPS and swap out to see if it fixes it. If it's seeing 17% TPS then it'll raise RPM as it thinks there's a foot on the accelerator. Seems most likely as when it's touched it drops back to idle speeds.
    Mar 2009
    Bexley NSW 2207
    17% is slightly high for throttle closed but only by 1 or 2%. try bringing it back to 16% and checking for air leaks.
    Jan 2010
    Newcastle NSW
    thanks heaps. I didn't know you could adjust them. How do you lower the percentage?
    Avoca Beach
    The accelerator cable wouldn't be too tight by any chance?
    You would have had to remove it to remove the plenum.
    Regard sPhilip A
    Jan 2010
    Newcastle NSW
    Hi Philip, the throttle cable has just a slight amount of play so it it is ok. I have checked the intake and it is fully closed. Im guessing it is either the idle control valve or TPS. Im just trying to guess which one now i think...
    Mar 2009
    Bexley NSW 2207
    it is possible to adjust the throttle pot on its two mounting screws (above the stepper motor) but you should never normally touch these. usually the problem is something else. check there is some slack in the throttle and cruise cables.
    check there are no air leaks into the manifold from, split hoses,
    bad gaskets, injector o rings or incorrectly fitted vacuum tappings.
    check the throttle blade has at max 2thou top and bottom and
    does not jam closed in the body. (if it is slightly out top and bottom, losen the 2 screws on the blade and let it slam shut 2 or 3 times then tighten the screws and recheck. if it is still out repeat the procedure but let it shut on an old 2thou fealer gauge).
    check live readings and check throttle position and if possible the learned throttle closed position, 0.6v to 0.85v.
    now depending on what model lucas system your car has and what scanner you have you can go further with adaption resetting but it would be easyer if you phone me (0421 509 083)
    Jan 2010
    Newcastle NSW
    Thanks Rupert. About to head overseas tomorrow so its a job for when im back in a couple of weeks. Ill be in touch then. The throttle cables have slack and the throttle blade all operates normally. I tried the allen key screw. Whilst this reduced the idle, the problem still exists as when i start it it is excessive until i put in gear then settles back in the same manner, its just the whole process just occurs at lower revs with the screw adjusted. If i order a new TPS, do i have to get the ECM reset??
    Mar 2009
    Bexley NSW 2207
    the adaptions should be reset but you don`t have to do it. also if you reset the adaptions on some early models they will run rich until an open loop tune is done.
    if your tps reads ok there is probably nothing wrong with it.
    i have a new tps as a test unit if you want to try it.
    If this occured imediately after you changed your injectors then highly likely it is related and simple, particularly with those things thjat have been disturbed during fitting of those injectors. For instance check hoses and plenum/ram bolted connections (used a light non setting sealant??) for air leaks, all cables inc cruise, TPS, ICV, fuel and engine temp sensor connections etc.
    One other thing your new injectors will atomise better and cause fuel to burn faster and sooner. I recall you have a Unichip so amount of advance might need to be backed off a couple of degrees with new injectors, particularly if it was agressively tuned at setup using old injectors.
