As said by others above - however if you are genuinely crossed up you may just need to use a few more revs to pin the free wheel and make the computer realise the wheel is spinning and apply the break. I need to do this with my Freelander but is the first generation 4 channel TC so does need a few revs.
On a recent club training day we had landies from my freelander to late model D3 doing wombat holes - generally the older systems required much more revs to lock the wheels and the D3 did not need additional revs at all. The one defender - about 03 model needed much more revs than the D3 for the TC to kick in but much less than my FL1.
So maybe you need to practice a little more increasing revs in the crossed up situation until the TC kicks in - noting as mentioned that if both wheels have the same level of traction then TC will not kick in as the computer needs to detect different wheel RPM to work.
